manes
For sale is an: 1971 340 magnum.
Motor is partially built. Machine work is complete with a .30 over bore and all other machining. Installed is a SCAT 4’ crank and bearings installed(new)
Brass freeze plugs install, cam bearing installed; comes with NIB KB hypereutectic pistons, SCAT Rods with bearings, ring set, engine gasket set, oil p/u extension, I also have the original cast iron 4 bbl manifold and the “j” stock iron heads.. the pistons for this build were to be used with aluminum heads. The iron stock one can be used if the dome on the pistons is machines off. I was following a build guide which Would displace 408 ci’s of 416 ci’s depending on how you complete the build. The guide I was following is included ( How to build BIG cubic inches from small block MOPAR) I think is the name of the guide I was following. It is truly an awesome guide for those who may want to to a future small block.
I am asking $1600. I currently reside in Port Saint Lucie Florida with the zip code being 34953
