Viking Crusader shocks
Talk with James from @PST he will make sure you’re taken care of. He worked on a custom order for my car and everything went flawlessly.
I need to get a measure so I know which shock, but yes, I will be sure to talk to James next week. Thanks
Those guys were really good to deal with BTW, called Viking, got the numbers, then called them, good communication throughout
The way I "J" hooked the LCA it hit. **** always happens. I already snuck out for a few test hits and all was good,but when I get to the track I might have to tighten the front up with the new intercooling system:)
Curious what you are running for settings on your front shocks, and if you tried different settings? Mine are one click from full loose and 2 settings from full compression.
It's amazing how tight you can run the fronts. I used to run both my QA1 stockers and Afco doubles nearly full tight on rebound. Now the Afcos have been valved 50% stiffer. Car is about 280lbs heavy on the nose.
If I can help in anyway please let me know.
Remember to use the FBBO discount and free shipping on all orders in the US 48 States
James
James
James is the guy to speak with about the Viking shocks. Knows way more than the guy I spoke with directly at PST. Thanks James
James
James,what can you do for a rebuild,I broke the knob off:BangHead::BangHead::BangHead:
