SOLD Floor Wiring Covers
hunt2elk
9:18 PM
WI
Feedback: 143 / 0 / 0
Decent set of floor wiring covers that came out of a 1968 Coronet. Will be the same for 66-70 B-bodies. One has quite a bit of surface rust, but the others aren't bad. I don't see any rust through. Will need to be blasted. $35. plus shipping form WI, or local pickup. Add 4% to the total if using goods and services.
20200415_115353.jpg 20200415_115400.jpg 20200415_115414.jpg 20200415_115417.jpg
I would like to buy these can you please contact me thanks . For some reason I click on contact seller and it won't go . Thanks
Just tried and can't PM you either. Maybe @Cranky or @kiwigtx can help us out?
Works for me....try clicking on the person's username and a small window should open up then click on 'start a private conversation'
If that doesn't work, I'll notify the site owner.
Yep, that's what I am doing. Just get an error screen.
@challenger r , Cranky thinks you have your message notifications turned off. No idea how to change that, but must be in your settings somewhere.
@challenger r , cranky thinks you have your message notifications turned off. No idea how to change that, but must be in your settings somewhere.
Place your cursor over your username up at the top right and a drop box will appear showing all the different setting you can go to.
Or if you are using a phone just tap the picture that's next to the inbox envelope.....
ok IM back yes interested how do we do the transaction I never bought on here before .
Did you get your inbox cleared out? @hunt2elk isn't on line right now but should be shortly.....
@challenger r, empty out your inbox like cranky suggested. As a non gold member I believe you can only have 10 saved at a time.
A Moderator or Admin can always get a message through even when the member's mailbox is full :thumbsup:
Wasn't sure about if a member can block mods or not so I sent him a test message.
Sold, thanks FBBO.
