EngineerDoug
Hey guys,
Asking for some opinions on the Mopar 528 solid cam. I am converging on my 500" stroker build; here are some key points:
Street use only, 3.54 gears, Torqueflite
3800 lb B body
Power brakes
John Cope specified converter, designed for this combination
440 based 500" stroker with aluminum heads
Solid cam
Closed chamber heads, with quench set for 0.045"
Static compression 10:1
Dynamic compression computes to ~7.6:1 using 528 cam
OK so I am pondering the critical combination of cam and compression ratio. Taking a hard look at using the 528 cam with 10:1 compression. What I don't want are detonation issues, crappy/unstable idle, hard starting, or engine vacuum below about 13" in gear.
So my key questions are:
1) Is this cam tame enough to meet my idle/vacuum goal?
2) Pump gas - OK to run 10:1 with this cam?
I know this is a tame build, given the amount of power I could make if I turned up the wick. This is not a daily driver, but if I get stuck in some stoplight to stoplight traffic on a summer day it should not be a headache, either.
Kerndog, I think I have seen your posts about using this cam in your big block? I am particularly interested in your input, as well as anybody else.
Thanks all.
3800 lb B body
Power brakes
Solid cam
Thanks all.
