- 8:30 AM
- Apr 13, 2012
- Granite Bay CA
I have a 383 that I just tore down and will be taking it in to the machine shop soon. I was hoping to just be able to hone it and reuse the original pistons but there was a ridge on every cylinder. I'm aware that I might have to bore it and use new pistons. I was impressed though that The rod and main bearings are all standard and dated 10-69, the block casting shows 8-27-69.
Ordinarily I'd just skip right past this and use a 440 but this is the original engine for my 1970 Charger project.
If I am faced with replacing the pistons, I'll do it but I am learning that these 383s with the short stroke they have are hard to build compression.
I've read terms like compression height and dome height. Summit lists several with a compression height of 1.908. This would be helpful if I knew what a stock height was. My pistons sat .076 in the hole and the calculated compression was 8.12 with stock parts. At zero deck, compression goes up to just a tad over 9.0 to 1.
Does anyone know of an aftermarket piston that results in zero deck or at least close to it?
