Recommend welding shop in Houston?
jeepthrills01
12:05 PM
Phoenix, AZ
My apologies if this isnt the right section for this..MODS feel free to move it.
I need to have the center section of my Coronet trunk floor replaced. Side and extension panels are good...but the center is swiss cheese from years of standing rain water from a bad deck lid seal and that good reservation sand/dirt.
I did plan to do it myself..but getting a few quotes from some real pros seem like my due diligence. Mainly cause it would be my first time dealing with a job that big..or important.
Thanks yall.
You probably want more of a restoration shop than a welding shop. What side of town are you in?
SW...but a trailer is available.i planned on dropping the tank and removing everything that's in the way.
I'm just looking for someone with a plasma cutter..a good eye...and a mig or tig.
Cut out the rust..zap in the new panel..heck I'll even grind down the welds.
Well..I guess I'm buying a Mig..haha..learning on the fly...measure once cut twice..right? :thumbsup:
Think I'd use a cut off wheel vs a plasma cutter. Easier to stay on line with it imo. You can make a straight cut with a guide but on a irregular surface, that's not real easy. Got the MIG, TIG, Plasma.....just not much time and the body is complaining more these days.
If youd be willing to instruct...I'd like the opportunity to learn...and do the labor...a guiding/ experienced eye is all I should need.
Ya its not that hard, If you are relacing the whole floor I think you will have to split it in half to get it in but if youre just doing a section iys pretty staright forward.
Of Cranky can help you out give me a shout...hes alot closer to you than I am bit if your in a bind Im in Conroe.
