WTB 1964 b body cowl
chad
11:33 PM
Guelph,Ontario
I know this is a huge long shot but I am looking for a cowl for my 64 fury.. mine its junk like most of them out there.. but just on the off chance someone has a parts car with a good one on it.
Touch base with a member/vendor here @moparmarks
Mark parts cars from his place in Colorado and might have or be able to get what you need. He just shipped some 64 Polara inner door panel trim to me a few weeks ago.
Will possibly settle for the aftermarket patch panels
You probably should stay with an original part. Sherman's sells a repair for the driver side. I've heard it's terrible. I also need a repair for the driver side, but I will wait for an original part.
I cant even get the patch panel here in Canada
The Sherman upper cowl panel is crap but it is useable if you don't mind reworking almost all of it. The lower or inner cowl panel hasn't been available since mid fall of last year. I got 4 revised delivery dates, then gave up and made my own. It's a pita to get the wiper post angle correct. I had to make mine in 3 pieces and weld together.If you can find the lower cowl panel,buy it.
Well so far I have had no luck getting g a OEM panel or the Sherman panel lol
I tried to order that panel from Jeg's, Summit, Carid, C2C ect. They all took the order then dogged me out for months . I just couldn't wait anymore. Not a fun piece to make either, but doable. I think Sherman is the only one who makes them.
We will be getting a couple in sometime.. I just don't know the exact date(s). We do
have a 63 Polara 4dr car here, we will be parting out soon. I think the under cowl
section is the same, but the cowl top is totally different than 64-65 cowl tops. Dodge33
Top of the under cowl for the windshield channel is different between 62-3 and 64-5. Same as the top piece.
Shouldn’t the 64 Plymouth and Polara have the same cowls?
Our Canadian Dodges for years were basically Plymouth’s with a Dodge front clip and rear end.
Yes Dodge and Plymouth share the same cowl and firewall.
2 cowls. 62-63 and 64-64.
3 firewalls. 62-3, 64 and 65. Same walls for a/c and non just different holes punched.
