Motor mounts
kinghs95
12:09 AM
Bartlesville, Oklahoma
What size bolt do I need to connect motor mount to k member? Also what size nut do I need to connect the top of the motor mount to the engine bracket?
Factory-style mount to K-frame thru-
bolt = 7/16-14 x 4" long
Buiscuit-to-bracket nut is 1/2-13
Woa! The hole in the frame is a 1/2 inch. Cut the nut off the mount and use 1/2 inch bolt, nylon lock nut and 2 washers.
That's a good thing to do, too...I think you could probably even get a 5/8" bolt through if you wanted, just for maximum beef! I put 1/2" bolts in with my solid mounts so there's still a wee bit of wiggle room for adjustment.
Perfect fit. I had already bought the bolts earlier today when I seen posts and it worked. But will consider cutting bolts off and putting 1/2 on it. Appreciate everyone for helping me out
