high speed ac blower mode
ord27
6:55 PM
texas
1970 coronet
The highest speed of the blower fan doesn't work. So, no difference between ac and max ac.
What do I need to fix this?
The heater fan resistor that is mounted on the outside of the heater/ac box under the dash?
if not, what and where can I get one of whatever?
thanks
Fan speed doesn’t change with max ac feature, that closes a fresh air door to recirculate mode. While it may sound faster it’s actually because the fresh air is shut off. As far as resistor, it is mounted on the air box where air traveling across will cool it, generally right below the glove box area. High speed is usually a direct 12v side of the resistor, then each speed becomes another side of the resistor . Check for 12v at the blower motor on high, then check the other speeds, you should notice staggering voltage numbers. If you don’t have 12 check the resistor for damage, the steel coils could rot off, or burnt connectors at the resistor, then also test the motor with a known 12v jumper to verify it works. If you have 12 volts to the resistor and the motor works good with 12v jumper then check for an open with a good voltmeter on the resistor, next you will need to test the switch for current going thru once again 12 volts then progressively goes down. A good quality volt meter, factory service manual and jumper set will be your best friend always find away to fuse it somewhere on the positive side. If your really confident a power probe is sweet but you must be very very careful.. best of luck
Great explanation and excellent advice. The original Chrysler "Air Temp" design, while complicated and heavy operated very reliably. Although the heater control valve assembly, confounded some service techs....then there is the EPR valve (Evaporator Pressure Regulator), hidden in the suction inlet port of the RV-2 compressor....a very mis-understood component. And....YES...the FSM is a must have, specific to your model and year vehicle...avoid the generic Chilton's or Motor's publications.... Just my opinion of course.
BOB RENTON
Bob thanks for reminding me about the EPR, I have run them with a conversion to R134A successfully...
