Power steering kit, is this a TRW ?
Suregrip391
8:08 PM
Niagara
Hi guys. I’m looking for a kit. Is this a TRW small pump, plain shaft. Any stores sell this? Seems guys have to find this one online....oddball.
A250C505-6D6B-4836-B64B-4051CC085F98.jpeg D2A1F718-CBA1-4B35-9F99-6C3C91D580F2.jpeg 07D5CC77-3A55-41D1-827E-F1FCE7CA2B98.jpeg 4543C04F-629D-4B20-B6E1-D522AA6B73E1.jpeg
That is a Federal. Not worth rebuilding just fit a Saginaw.
You can buy a kit of 440 Source.
They look similar but it's easier to tell if you can see the back.
I mentioned TRW because in my pic I posted, to me it did look like the one on the left Photon440 posted. What did I miss? Thanks guys.
Actually now that I look closer, it does not look like either....but closer to a TRW
Yes that is small TRW pump. You can tell by the shaft being solid. Federal pump has a 3/8" Threaded hole in shaft. Both can be rebuilt. And that federal pump was a hemi pump and AAR Cuda, and the non core cost is about $600 at RA now. So I am not sure I would just scrape one if you had one.:)
I believe the edelmann 7897 or gates 350370 kits are what you need. It is confusing on RA as they call them Chrysler pumps but use saginaw bearing terminology. But the parts they show in the kit are the Small TRW parts and bearing. Not all kits have the bearing.
Thanks Guys, I converted from the TRW and and did the Saginaw conversion. All went well but noticed the pump had a knock noise noticeable at idle. Quieter athigher RPM but still there. I bled the air. Is this normal? I used PS fluid, not ATF.
Hey Dragon Slayer , your inbox is full... I had a question for you. Do you know what kit part number would be used on a TRW pump with the Hex shaft? That’s the pump on my other car, fired it up today and it’s now leaking.
Cleared it out, but I do not have a kit number. That would be the large pump. Maybe Rock Auto.
Id go with a TRW or Federal before a Saginaw everyday of the week. You can buy a kit to rebuild.
I posted a thread on kits and correct part numbers for a couple style TRW pumps.
I have a TRW but seal leaking goy a rebuilt federal but looking for pulley shaft is about 5/8 ya know where I can buy?
big thumb I am looking for a pulley for a federal pump shaft is about 5/8 inch in dia.
