Sonny
I installed a new blue high rev box on my 440 Belvedere and the instructions say that when the key is in the run position (car off), the voltage at the coil should be 7-9 volts. I have 6.7. Is this an issue? If so, what could cause the low voltage? New stuff I added months ago: harnesses, coil, ballast resister (came with ICU), battery, 95 amp internally regulated alt (removed the VR), bypassed the ammeter, stock dizzy, installed larger alternator wire to starter relay with fuse able link. Starts, runs and drives fine.
