gdunmire73
Welcome to FBBO from OHIO
Thank you.Love the Moparsaboard. Great save Builderguy !
Man thank you so much.any idea where I can buy thoseOkay, got lucky. There were at the bottom of the bottom tote. This is off a 73 roadrunner.
View attachment 999218 View attachment 999219 View attachment 999220
Bolt is #3402 650 and the nut is #6024 803. Let me check the garage as the upper control arm may still be in a tote and not in storage.
Welcome from North Carolina.
Try posting your question in one of the tech forums. It will get a lot more views.
https://www.forbbodiesonly.com/moparforum/#classic-mopar-tech.17
Thanks.Mopar guys are the bestwelcome to the site,someone will be able to help you.
Thanks.Im glad to be here.Im sorry I missed your post earlier.Welcome aboard Sir, from the middle of the mitten. I have a soft spot for 73's
Thank you.Its the square bolt that comes up through the mount bracket on frame and goes into the cross shaft.Another fellow actually found it but I'm not sure I can get it.Welcome from Michigan. I went thru the same issue when redoing my car. Ended up buying all 3 kits before I got it right thanks to my neighbor.
Do you need the upper control arm adjusting bolts....
the upper control arm Camber bolts....
or standard control arm bolts....
Thanks.builderguy got it.now if I can find them.aboard. Great save Builderguy !
Thanks.I have been looking through the site for some time.Figured need to get on here.Great info.Welcome from NY
Thankswelcome to the site,someone will be able to help you.
Thank you.Welcome from Alabama, sorry I'm not up technically on the 73-74's.
Thanks budg'day from Australia![]()
Thanks.Color isAutumn bronze.Welcome from Missouri!! Nice color!!
