burrpenick
- 8:31 AM
- May 9, 2016
This is a friends car in Port St Lucie Fl. Ebay link, he built it himself, so he knows everything about the car. It regularily driving on the road. Price is going to be around $50K: https://www.ebay.com/itm/1969-Plymouth-Road-Runner/303710707915?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160811114145&meid=5524cdc3e68e463499aa0d671353bec6&pid=100667&rk=1&rkt=8&mehot=none&sd=303710707915&itm=303710707915&pmt=0&noa=1&pg=2334524&_trksid=p2334524.c100667.m2042
Here is the description:
Plymouth Road Runner. Reimagined with a modern drive line, newer challenger seats front and rear,Vintage air A/C, electric windows, 70s style Classic dash, Has been driven to car shows up and down the east coast of Florida and the paint reflects that, paint is about 5 years old, passenger door bottom has a few bubbles at the bottom,car looks great though, has a 2012- 6.4 hemi with matching 6 speed manual transmission, tremec tr 6060, with hydraulic clutch and a aluminum driveshaft by the driveshaft shop, 8 3/4 rear with 355 posi, recently rebuilt with new gears and warranty, posi is tight, 4 wheel power disc brakes, slotted and drilled rotors, TTI headers, x pipe, 3" exhaust with large quiet mufflers, Tanks inc, EFI fuel tank with baffles, Front and rear sway bars, graphite bushings, tubular upper control arms, gusseted lower control arms, Mini tubbed rear wheel wells, frames tied,Pioneer head unit w/USB ,6x9 Infinity speakers, drivers seat is power,horn is not connected, fuse box is upgraded to atc fuses, tires are new, 17x8 front and 17x11 rear torque thrusts, headliner is new, engine is 470 Hp 470 Torque and it gets 23 MPG and will run a 12.50 1/4 mile with these hard low profile tires. I will not give out the reserve but its reasonable, Call if you have questions or want more pictures Richard at or text , Don t bid if you do not have the money, and get permission before you bid, this is a binding contract, 500.00 due at end of bidding, non refundable.
