Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
If just the tin has burned not the structure I’d redo it. I seen a triple black 383 4 gear 70 charger like that and it’s stunning now.. it’s all up to the owner I’d at least get some second opinions and slow up on scrapping it ...there are lots of parts still available from a used front stub to used rails . Sad sad sad I’d be devastated but I’d be building it back.. it would take me a long time as I try to use only good used parts. Someone save it! My shop is full.
A good lesson here is to completely remove the old wiring and bulkhead connector and replace with new updated wiring. Also eliminate the ammeter from the whole system. The MAD Electric upgrade is the way to go also. Just makes sense too because most of the original wiring is brittle and dry rotted insulation. I did on my 66 Ply Sat and by passed to ammeter and ballast resistor from it...cr8crshr/Bill
