Fuel level gauge
Aron Gleason
8:31 PM
Washington
Trying to get the factory gas gauge to work with my jaz fuel cell. I have the blue gauge wire hooked to the sender terminal on the cell, and one wire hooked to the ground terminal to the strap bolt holding the cell in place. Turn the key and nothing. What am I missing?
Ground the blue wire and see if the gauge goes to full if it does the sender is bad.
I did that, gauge works. I need to get a 70-10 ohm sending unit. The one in the fuel cell is most likely a GM unit.
