FOUND 11.75 dust shields
Beekeeper
It’s a disease without a cure!
7:20 AM
Rogersville,TN.
Feedback: 16 / 0 / 0
Looking a pair of dust shields for the 11.75 discs in good or repairable condition.
I believe that the 10.87 and the 11.75 use the same dust shield and thats one of the ways to tell what size the rotor is when searching for disc parts, if you can't see much of the rotor than it's the smaller rotor and if you can see about 3/8 or so of the rotor sticking out from behind the shield its the larger 11.75 rotor. So you should be able to use the shield from either brake setup.
Yep that is what I have.
I have what i need then thanks for the help guys
