FOUND 68 GTX Convert door & quarter trim
Wojo68
11:43 PM
Boston Ma
Feedback: 12 / 0 / 0
I am looking for both pieces of trim. One for the driver's side door (the piece that sits on top) and the other one for the driver's side quarter (shorter piece, on top). Any help/leads would be appreciated.
The door trim is the same as a hardtop... I had to find a door trim for my Coronet R/T Vert...
I don't know if Dodge & Plymouth door trim are the same...
Quarter trim will likely be a little harder to find...
I wasn't sure if the hardtop was the same trim. Thanks R/T
No problem.. Do you still have the original trim? A good trim guy can fix stuff you wouldn't believe... I wouldn't spend much on fixing the door trim but the quarter trim might be worth fixing...
I have the right side only.
Door trim appears to be the same... Which probably means the quarter trim is the same... I think I have a spare drivers door trim... The notch near the front of the trim is the giveaway that it's the same.... These pieces are for my car, I have them in the house... The spare trim if I have it is at my storage.... I'll ty to get a look tomorrow but if not I'm gonna be out of town for work all week...
The only part that is different on the upper belt moldings between Dodge and Plymouth Convertibles is the small transition piece. This is where they make up for the longer wheelbase of the Dodge. The corner pieces in picture are the same for both brands. All the stainless trim is the same.
I will look and see if I have a single. I know for sure I have complete sets.
I checked my storage, the single I have is for the passenger side.. Sorry.. Good Luck, I'm sure someone here will get you hooked up..
BTW 68-70 Plymouth & Dodge are all the same... Rear trim is vert only but again 68-70 Plymouth & Dodge..
No worries R/T, I very much appreciate the effort.
I checked and I only have 2 sets of convertible qtr. door belt trim but they are part of entire sets with door trim and convertible well surrounds.. No singles so sorry I Can't help ya.
That's ok. Thank you for checking for me.
