Gary P
- 6:49 PM
- Aug 21, 2019
- Pleasant Grove, Utah
Hello guys, and a happy new year to you all.
I wanted to ask some advice regarding removing a steering box from my '78 Monaco. I assume the same year Fury, 300, Cordoba and a few others are much the same, if that helps anyone with experience. I have a couple of shop manuals that hopefully pertain to this year, but I thought it no biggie to ask you great fella's.
I have the lines off, and I can see the two huge mounting bolts, the pitman arm is easily accessible so my questions are:
Am I going to be able to get that off with the manifold right there?
Also, what's the trick with separating it from the steering column? Is there a pin to bash out or does it slide off from a presumably splined end of the steering shaft?
What's the deal with bleeding once I've put the new box in?
I promise I have used the search tab, it keeps coming back with an error. I've looked on youtube too, there's some info but it's a scary task for me and wanted to get as specific as possible.
Your guys' help will be greatly appreciated!
Thank you! Gary.
Thank you! Gary.
