How to replace the rubber? ‘71 Charger SE side rear Windows.
71SandbugCharger
7:11 AM
California
I got the replacements from Detroit, and the window cleans up really well with cooktop cleaner! How does the old rubber come out? Slide it out, pry it out? Suggestions, please! Thanks
3AE00C56-8638-4679-9608-6E9C72D038BE.jpeg C339F790-3FF0-43F1-B5C5-DFDFAB8A9F44.jpeg
It should slide out of the chrome channel. Might have to lube it up to slide it out and not damage the chrome channel.
Take care as the chrome strip is a friction fit on the glass. I'm sure there's a way to remove it, clean up the edge of the glass, and reattach with a caulk, but I've never done it before.
Thanks for the stovetop cleaner tip on the glass...might have to look into that on some really crusty glass I have.
Removed the old seal, the new seal slides in and this little metal tab goes through the whole in the rubber seal.
Used some silicone spray as the seal was a very tight fit; which of course you want.
As we know with most repro parts they are usually a little off, the hole that was drilled in the seal was out of place so I had to drill a new whole and it had to be a little more oval for the rubber seal to fit over it.
Finished product, I am very happy with it and glad it was available in the aftermarket, mine have always looked like crap.
29154056128_108e4070af_z.jpg 43297005972_204c64333a_z.jpg 29476325948_443f2a2ea4_z.jpg 42442233365_3da279c381_z.jpg 33619768438_792d8d96b7_z.jpg 33619768438_792d8d96b7_z.jpg 33619768338_05ef9b24a9_z.jpg 33619768288_360b084db6_z.jpg 33619768228_18f9a46212_z.jpg 33619768178_e8ec4a6df1_z.jpg
View attachment 1067438 View attachment 1067439 View attachment 1067440 View attachment 1067441 View attachment 1067442 View attachment 1067443 View attachment 1067444 View attachment 1067445 View attachment 1067446 View attachment 1067447
Thanks and thanks for the helpful tips and all the pictures! This will help me to put the whole window and guides back together!
