Coat hook location
pnora
7:28 AM
Ishpeming, Mi.
I am in the process of putting my 69 Charger back together and need some help locating two holes on each side. The headliner was replaced. Prior to replacement I made a template with measurements where the coat hook and shoulder belt elastic strap snap went. Well I can not find it. I have located the large shoulder strap hole. If some one has a car apart and could measure from the shoulder bolt hole to the coat hook and to the snap hole that may help me zero in on the spot. I assume all 68-70 B-Body hard tops should be the same. Thanks.
Could measure an assembled car also. I think it has to be a 68-69. A 1970 doesn't have the elastic strap on the shoulder belt or the bucket latch piece on the sun visor mount.
Never thought of that. So if someone can measure a preferably 69 B-Body that would be great.
I can make some measurements off of my convertible.
68 GTX.
Thank you very much. Gives me an idea of the contour and approximate hole location.
I had a new headliner installed in my '64 Polara and decided to shitcan the coat hook. Can't remember the last time I had to hang a coat up in my car.
