WTB 70 Air Grabber parts needed
tallhair
Rufus "Mod-hair" Firefly
Staff member
6:16 AM
Mascoutah, Illinois
Feedback: +14 / =0 / -0
Looking for 70 Air Grabber parts
Need 3 hole 3/4” firewall grommet, decent usable hoses, dash solenoid, dash trim pad with AG switch bezel and screws if possible, left pad, spring clip for back of switch that holds molded hose plug to the switch, and trico canister PN on bracket 344115.
Almost everything was removed from my car unfortunately.
If you have any or all or some of these parts please PM me,
Honestly, you already have the dash pad you need. If you took the lower/driver dash panel off where the airgrabber switch goes & look behind it, you'll find a template of where to cut the hole for the air grabber switch. Even if it isn't "perfect", the air grabber switch bezel will cover the hole.
For just the "toggle" on the air grabber switch (the little red lever slides off the actual switch), it is exactly the same as those found on C-bodies (for their A/C or something???) except the C-body ones are chromed plastic which can be painted red.
Hope this helps at least a little
