FOUND 73-74 Big Block AC Pulleys and brackets
T2R9
7:20 AM
Conway, SC
Feedback: 31 / 0 / 0
I need a complete set of pulleys and all accessory brackets like the idler and alt bracket for my 74 Rallye. PS pump too.
I have some brackets, not sure if they are what you need. Could you post a picture? Thanks
This is what I am looking for. Alt brackets, pulleys, tensioner, and PS pump, or pulley and brackets. I don't need AC brackets as I am going with the Sanbon unit. I need two upper pulleys.
I have boxes of brackets and pulleys. But I would need some pictures of the brackets you need, to match them up.
I also have the pulleys marked with their measurements. If I can be of any help you cam PM me the pics and or details.
Here are the parts I need. Lower pulley is a 4 groove 3-3/4" deep and 7-5/16" diameter. Alt brackets as shown with spacer and tensioner. I do not have an upper pulley to measure. I is the small single shallow one like pictured above. I also need a single rear Saginaw big block PS bracket. Prefer to find a complete set removed from the same car and not try to piece meal it together.
I might have that stuff in storage. I will be heading over there tomorrow so I can check...
Just so you know that is the 70-73 setup. That all changed in 74.
I should have the 73 setup.
I will be good with the 70-73 setup.
I have the 3 pulleys, spacer and alt brackets. Rounding up the bolts. On your crank pulley did you need the 70-older with the one offset bolt hole or the 71 and up with the even bolt holes? Working on the P/S brackets.
