PLMHEMI
- 10:27 PM
- Oct 31, 2019
- Ray Twp, Michigan
Most people put the numbers to the rear so you can read them. Ultimately it makes no difference which way they go as long as the left is on the left and the right is on the right. Which end is stuffed into the lower control arm makes no difference.
What would be the difference between it and any other B/RB block distributor hold down bracket?
Yes same one..is this not the same one for a 426 max wedge?
