- 12:44 PM
- May 14, 2011
- On the Ridge, TN
Had an issue the other day with the 4 speed in Fred (18 spline A833, rebuilt).
Had to back up and the darn thing wouldn't go into reverse; the shifter has
felt pretty sloppy since I had that mechanic replace the transmission and clutch
last year (and it shouldn't, since it's pretty dang low miles).
I go out to the garage today to begin the clean up routine for Spring and decided
to play around with the shifter and it's still acting really off, so I pull the boot off
and watch the mechanism - and see the entire shifter adapter plate wobbling
around on the side of the transmission tail shaft.
Looks like I have to take the shifter off and do something with the adapter plate,
praying that the plate mounting holes on the tail shaft aren't buggered out.
Problem is, the previous owner "converted" Fred to a 4 speed and the sheetmetal
cut out of the floor pan that he did to mount the hump in the floor is seriously
raggedy and there isn't any room for my hands/meat cleavers to get in there and
remove the shifter bolts.
My question:
Can I just put a jack under the tail end of the transmission, temporarily remove the
trans crossmember, then lower the back of the transmission enough to access the
shifter bolts?
Will it drop enough doing things this way?
(I'd love to beat the hole in the floor with a sledge to get it opened properly, but
that's gonna take dropping the transmission, something I'm not currently in any
condition to do).
Thanks!
My question:
shifter bolts?
condition to do).
Thanks!
