Dome light placement
70BurntRt
4:40 PM
Silver Spring, MD
Can anyone tell me where the dome light is supposed to be mounted?
My charger had a aftermarket dome when I bought it. There are four screw holes in the center support. Does it mount to the front, rear or is there a bracket I am missing?
The dome light on your charger is sheet metal screwed into the center of the roof brace, slightly behind and above your head as you are sitting in the drivers seat. If you look closely you will see the original screw holes. the wire harness for it runs immediately to the left side, then forward to the pillar and then down to the lower left side where it gets connected. The metal body of the dome light is the bracket that bolts up there.
Wiring run..
Can you send me a pic of the actual screw holes in the support? I’ve got the wires in the right place. I just don’t know where to mount the light. Mine as four holes, two towards the front of the support and two towards the back. That’s why I wasn’t sure which one to use.
thanks.
Do you remember if it’s screw to the front or rear of the support brace? You probably can feel for it and tell.
.or one of the 1000 guys here with their car still blown apart could step up to the plate... :poke::luvplace:
Did you get this sorted I have the same problem, 4 screw holes can be mounted either to the front pair or back pair??
I’m pretty sure it’s the front holes, with the bulb facing towards the rear. I’m not near my cars, but perhaps someone here can pull their done light lens off to verify.
Mounted on the front holes, light socket facing towards the rear window.
You gotta be kidding, that’s the only thing left original on my car. Between the previous owner and the thieves, my Charger still has the headliner. I know you posted this a while ago.
:lol:
