SOLD 971 Oil Pan - Unused
nascar37
9:52 PM
Avon, NY
Feedback: 8 / 0 / 0
Mopar Big Block B and RB Oil Pan
Moroso 5 Quart Chrome Pan
The pan sat in storage so it does have surface rust but is completely unused. It has completely straight mounting rails.
$125 plus shipping from Avon NY 14414
Why would you describe a pan thats had the sump cut off and a deep sump welded on as
A) un-used, it may have not been used but clearly it's been modified and chromed...
B) 5 quart when it has an 8 quart sump welded to it...
Here is an un-modified 971..
This is a Moroso Oil pan not a Mopar factory pan. It does have the “971” model designation on it. I apologize if there is any confusion
FWIW it started life as a factory Mopar pan & was modified... If Moroso did the modifying then that pan probably dates to the 70's or early eighties.. I know at on time they sold a DIY kit that you would cut the original sump off & weld on a new sump.... Cool piece... Good Luck, hopefully a buyer comes forward..
I had those pans in the 80s and 90s. That is not a home made pan. Moroso sold hundreds of those pans. That’s is Moroso’s number, not Chrysler’s number. It has nothing to do with the Chrysler pan other than the same 971 pan That shows it will fit anywhere that a Chrysler 971 pan fits. Kim
Based on several follow up questions, I believe this to be compatible with Moroso pickup part number #24750 but I suggest verifying this with the manufacturer. The pan depth is 7 inches.
