Thanks pnora. That's a big help! I'll try it out.Yes it can be accessed. If the antenna is extendable pull it to its longest length. Find a weak station and tune it for best reception.
I wonder why plastic or ceramic?Best to find a station around 1200kHz and just with a plastic or ceramic screwdriver.
I have always used steel screwdrivers. Never heard of needing plastic or ceramic in these applications. I have been tuning these since 1968. I am sure there could be some non automotive applications that needed them used. For your 1968 just tune it as I suggested.I wonder why plastic or ceramic?
I understand what you are saying however in all my years trimming an antenna I have not had any difficulty or problems doing it with a short steel screwdriver. I have never seen a FSM even reference using a plastic or ceramic screwdriver. Back in the days of AM only radios in the dealership we most likely set 50 percent of them. Most people in our area wanted the AM station in the 500 kc range which had the Detroit Tigers broadcasts.A capacitor is two plates across a dielectric. The trimmer screw itself is connected to one plate of the trimmer capacitor. A metal screwdriver unbalances the capacitance. Also, the trimmer is connected to the RF amplifier and a metal screwdriver, especially a long one is defeating the goal of balancing the input tuned circuits as you are connecting another antenna with your long screwdriver.
I used to have a bunch of cheap ceramic screwdriver I bought in Hong Kong in the early 1990s that I would give away with every radio I serviced, but my supply has diminished over the years.
I tried to adjust the trim with the antenna up all the way and tuned to the best station (which was prwetty bad) around 1400. I adjusted it about a half turn clockwise and the station got better (but still not very good), but coulds not turn it beyon that amount. It seem the screw will ony turn about one full turn total. Does that sound right? I had just fixed my antenna cable by splicing a new connection at the radio because the signal wire had got broken there years ago and this was the first to try it out. I wonder if that is part of the problem as it is a little longer than original by few inches. I though I read the cable length has some affect on tuning the trim. Thanks for your help.I have always used steel screwdrivers. Never heard of needing plastic or ceramic in these applications. I have been tuning these since 1968. I am sure there could be some non automotive applications that needed them used. For your 1968 just tune it as I suggested.
Do you think. Get a new antenna.I tried to adjust the trim with the antenna up all the way and tuned to the best station (which was prwetty bad) around 1400. I adjusted it about a half turn clockwise and the station got better (but still not very good), but coulds not turn it beyon that amount. It seem the screw will ony turn about one full turn total. Does that sound right? I had just fixed my antenna cable by splicing a new connection at the radio because the signal wire had got broken there years ago and this was the first to try it out. I wonder if that is part of the problem as it is a little longer than original by few inches. I though I read the cable length has some affect on tuning the trim. Thanks for your help.
