4mulas
- 12:14 PM
- Mar 16, 2017
- Just North of Great Falls
Hoping someone has a working ammeter outside of the car that they can test what the ohm rating is between the terminals.
Just doing some trouble shooting and would really like to know. I had power in the car, lost power in the car and have trouble shot it to the ammeter. Fuse link is good, goes through the bulkhead fine and then into the ammeter but not out. Upon further examination the black terminal was little loose, when I tested with the ammeter there was no reading, centred the post terminal of the ammeter, tightened it and now I have continuity.. did and experiment and loosened the terminal more than initially found and it had rather high resistance in ohms. Took my time, centred the terminal and tightened it again a now had nice low ohm reading of .3 I’m considering using the ammeter again or also considering bypassing it and being done with it in case it is suspect..
Regardless if someone can give me a reading in ohms on a known working ammeter I would appreciate it.
