John Tipps
Ive replaced the 440 heads w trick flow 240's and roller rockers and I cant seem to locate valve covers that fit,the stock ones are too short, Mr gasket fabricated ones sat down all the way but the tubes for the bolts are at the wrong angle,you can see the holes but the bolts wont line up and the ones I just picked up from Summit (4th try) measured out correctly but will not press down and seat,the right side is up 1/4" too far, has anyone been through this or have some good info? Trick Flow valve covers I hear (by them) will fit but aren't available till September...any thoughts?
