- 7:30 PM
- Oct 16, 2014
- Salisbury, Vermont
Have this one...
Need this one....
Need this one....
This is the pan I have. Center sump with a baffle plate. The straight one should work.Can’t see the pic of the one you need. If it’s the straight one I have it.
whatever stock tubes are...I think so. I'll measure it tomorrow.Is that a 1/2 tube?
1/2 is the Hemi tube, 3/8 is for a stock 440.whatever stock tubes are...I think so. I'll measure it tomorrow.
I'll see. Several others are trying to help me resolve this as well.I just went through the same problem. The straight melling 63-s3 will not resolve your problem with that low capacity low pan. It will end up in the same place hitting the pan were the drain plug is. I just bought the proper 6qt pan and used the oil pick up that you pictured. However I did surmise that if you cut and rethread your original pick up or the straight pickup by about an inch that it would reduce it's depth in the pan and place it more towards the front of that pan. I do have a new 63-s3 pick up if you want it for cheap.
