Identify these please....lol.
Brandy
Jack Stand Racer #6..and proud of it!
11:16 AM
Salisbury, Vermont
Help me out here.... what the F88K are these brackets? Thanks..
Left one look like the bracket that bolts to the ear in the tranny and is part of the shift linkage would normally have a Nylon bushings.
I thought the left one might be a frame mounted bracket for a brake line hose?
#1 Is likely an automatic trans torque shaft bracket (without the bushing). #3 Is the vent wing bracket. #4 Is a guess: It looks like a window mechanism part.
1 shift linkage mount, bolts to drivers frame rail
3 vent window support, bolts inside the front of the door
6 A/C Receiver Dryer mounting bracket, bolts to right inner fender
I asked the same question when I removed mine, it was bolted to the driver's frame rail near the firewall. The answer I got then was it had something to do with the column shift (mine had been long-converted to floor shift).
This used to be a column shift too...
