69 gtx gas pedal
revmaster
6:54 PM
Winnipeg Canada
I have a 69 gtx automatic. Does the gas pedal just rest against the arm ?. The arm has a small hole like for a cotter pin to go through . But my pedal is just tapered curve where it looks like it sits against the arm . No where for a pin in it. I found this rod does anyone know what this is. Thanks for any help
I have a 69 gtx automatic. Does the gas pedal just rest against the arm ?. The arm has a small hole like for a cotter pin to go through . But my pedal is just tapered curve where it looks like it sits against the arm . No where for a pin in it. I found this rod does anyone know what this is. Thanks for any help View attachment 1130466
That looks like some sort of shift linkage rod. The 69 pedal hits a roller on the firewall bracket assembly.
What does that rubber bushing do on the roller in the pic? Thanks for the pic and info
Not sure what you mean by rubber bushing on the roller. The roller is just that. It rides on a ramp on the back side of the pedal.
