FOR SALE 1969 Dart Custom $12,500
Carguy47
7:10 PM
Phoenix
Feedback: 1 / 0 / 0
For sale is a 1969 Dodge Dart Custom project - clear AZ title
Old drag car: subframe connectors and roll cage
HEMI fiberglass hood scoop
Mid 70's 440, Edelbrock aluminum intake and carb
Holley valve covers
NEW electric fan and relay wiring
NEW fuel line
Fenderwell headers
Rebuilt 727 transmission and torque convertor
NEW Hurst Pro-Matic ratchet shifter
NEW Champion radiator and hoses
NEW master cylinder
NEW carpet
NEW dash pad
Superstock seat risers and Bucket seat
Aluminum fuel cell
Battery disconnect switch
NEW 3-point seat belt
NEW glove box
NEW Competition Engineering front and rear shocks
NEW fuel filter and electric pump
Refresh wiring harness
NEW tach and gauges
Repainted grill
NEW front marker lens and bulbs
NEW headlights
Insulated headliner area
Original rearend and front suspension
Four wheel drum
5 on 4 bolt pattern
Holley valve covers
NEW fuel line
Fenderwell headers
NEW master cylinder
NEW carpet
NEW dash pad
Aluminum fuel cell
NEW glove box
NEW tach and gauges
Repainted grill
NEW headlights
Four wheel drum
5 on 4 bolt pattern
View attachment 1137502 View attachment 1137503 View attachment 1137504 View attachment 1137505 View attachment 1137506 View attachment 1137507 View attachment 1137508 View attachment 1137509 View attachment 1137510 View attachment 1137511
Wish I had the Bucks. I would snatch it up for the wife grocery getter.
What rear end is that? And what gear ratio?
As mentioned, the transmission was rebuilt and has not been run yet, NEW torque converter. Motor is out of a motor home. I heard it run and it came with the Edelbrock intake and carb. I took the heads off and it looked good. Put them back on, new gasket.
Paint and new hoses. Started wiring harness rebuild and it is in the car. The horn shorted and burned the wire in the column. I have a NEW aftermarket 12 fuse wiring harness for the car. Just not installed yet.
I also have a NEW rear spring relocate kit and super stock springs I can provide IF the asking price is met.
