66 charger manual to power steering change.
buckmaster607
4:52 AM
New York
I have a 66 charger that came from factory with power steering and air. Someone before me took both off, would like to change back to power steering. I found 2 66's and 1 67 charger at an "old" junk yard. Anything special I would need to do to change over? Different steering column? I have a 318 poly, double pulley already on engine. Thanks!
Is the power steering box in the car?
If they used an adapter on the steering shaft to lengthen it to use a manual box then all you need to do is take is off. It looks like this. If that is the case you won’t have to change your column.
Would there be any concerns using gear box and pump that's been sitting for so long?
