Oil Leaks Found
padam
8:14 PM
Canton, OH
Here's one for you online trouble shooters.
I just rebuilt my 413 last winter/spring.
I was feeling pretty good about things since it was running well, (not as fast as I would like) and seemed to be sealed up good. The only leak I was aware of was slight dripping from the oil pan drain plug, very small amount from a valve cover.
Last week I got run off the track for leaking oil. I really couldn't see it leaking even with the engine running. But there was a lot of oil on the pan and drag link.
When I got it in the garage, the next day there was a lot on the floor.
At first I found a dent in the front of the pan sump, cause by a matching blob of weld on the k member. I must have dinged it when installing the engine. The pan is original, and is pitted out side, so I figured really thin there. It was definitely leaking here, but not enough to explain the qty. Time to install the Miladon pan I bought awhile back to solve the sloshing issue.
Not feeling good about having found the problem, I looked through the oil leak threads here, and was getting ready to try to pressurize the crankcase. I was really looking over the bottom, and and saw the the dipstick tube is cracked just above the block. That explains things a lot better, but of course it will be a much tougher repair.
Moral of the story? It's easy to jump to conclusions when diagnosing a problem.
Glad you found your problems. Myself on a rebuild or even if I had the engine out for detailing the pan and dipstick would of been replaced if at all looked rusty or compromised.
Absolutely, I see it all the time reading through some of these threads. Many jump to the finish line, without ever running the race. Do this ! ... do that ! ... change this ! ... replace that ! Without ever knowing what's causing the issue in the first place.
I did replace the dipstick. I wasn't real happy with it since the chrome started flaking off right away. I switched it out for a no plated one I had.
I had to bend the tube quite a bit to get it to fit, so that's on me.
This is a 64 engine in a 73 charger with 318 k member and factory bb mounts, so a mongrel when trying to get parts.
Can anybody recommend a good dipstick and tube?
Yes and then on these forums they list all these expensive aftermarket parts & gadgets YOU NEED to stop the leaks.
No, you need to find what is actually leaking and fix the problem.
" Online troubleshooting " is kinda fun though! Keeps the brain pan cruising along. I don't like chrome dipsticks either, Mancini/Summit/440source?
Seems weird that an oil pan can rust through, but I have changed several over the years, on different makes of cars.
Just part of being in the rust belt.
Loo
I got it from Marsh, but it was an off brand name that I don't remember.
I picked up the engine used in 84 and the pan was on it then. Engine was siezed , probably sitting on the ground.
Loo
There ya go. Check,check and recheck!
Got the drag link down today, used the tool pictured and it worked great. I also ground off the offending weld splatter.
