Can you identify this engine?
Bob Sawyer
12:07 AM
Chesapeake, VA
Can anyone identify this engine? It is in a 1966 Coronet.
Looks like a 318 polyshere A engine.
Apparently the upper radiator hose didn't make it run any better.
Don's correct. Definitely a 318A Poly. These engines will run forever if properly maintained. If you want to know more go to Polyspherical AKA Poly 318 on Facebook. There are also a couple POLY owners here, like myself.
dump it, bolt in a 440...& proper trans & rear......(drive train !,2 3rd member)
it will work in that setup ( need the right oil pan)...done:thumbsup:
:usflag:
:usflag:
Or keep it and re-build. Great reliable engines, although I may be biased...
I think a stroker poly with a hidden nitrous setup in a 62-65 b-body four door could be the greatest sleeper in the Mopar world!
Except for dizusters raggedy 62!
I’m with you. Didn’t cost that much more to build my Poly. AND I like hearing, ‘what is that?’ Even from some MOPAR guys. Bore it .040, drop in a 4” crank and it will give any 440 all it can handle.
Loads of potential in Poly 318's, not too hard to stroke.
