- 11:59 PM
- Feb 20, 2012
- New Hampster
Just ordered the 40 gallon tank.
Well done.Just ordered the 40 gallon tank.
What are you planning to use for cleaning agent?
Klean Strip Orderless Mineral Spirits. Like everything else, it's expensive. Not as good as Trichloroethylene but not as carcinogenic.That's what I've got to figure out. In the Eastwood video, the solution they use makes a small pile of bubbles which makes me think it's water/detergent based, but as we all know, a petroleum based solvent works best. Any suggestions?
I'm almost certain it's what was used in dealership shops back in the 70s. BTW, the CDC describes it's primarily used to degrease metal parts.Triclor would evaporate in a few weeks, great cleaner but not for a parts washer.
It's also the main ingredient in this, which is why it does such a good job.I'm almost certain it's what was used in dealership shops back in the 70s. BTW, the CDC describes it's primarily used to degrease metal parts.
It is used mainly as a solvent to remove grease from metal parts, but it is also an ingredient in adhesives, paint removers, typewriter correction fluids, and spot removers.
Ive never had the chance to use it, but it sounds like a decent product, petroleum distillate. Try a can, your not out much if it doesn’t work out. On the other hand, it’s “foreign made”! Make sure there are no dead Wuhan bats floating around in it.Any thoughts on this stuff?
https://www.tractorsupply.com/tsc/product/crown-psc-1000-parts-cleaner-5-gal
Looks like a better choice than odorless mineral spirits as it is cheaper and has a lower flammable rating of 1 as opposed to 2 for the oms.Any thoughts on this stuff?
