FOR SALE Dual Snorkel Air Cleaner
VFilms
11:16 AM
Saratoga NY
Feedback: 2 / 0 / 0
I bought this air cleaner to use with my WCFB as it is 4”. I’ve replaced the WCFB with an Edelbrock with 5 1/8”. I’m not sure what year MOPAR it’s from, I’m guessing someone here knows.
It has been professionally powder coated from a nearly rust free piece. The top measures 17.5” across, 3.25” high and 4.25” to the top center.
It comes with 2 bases, both 4” opening. One base has a 1” drop and the other has a 1/2” drop. The base with the 1/2” drop has a small strip cut out along the out side. The original owner must have cut out some rust as that’s how I got it, which is why I have the other base.
I have about $450 invested. I’d like to sell them for $300.
F76A3D59-7E75-44C3-A177-2F071F9F4F31.jpeg FF90DD1C-5914-46F7-B6D1-C29461552672.jpeg FC57D5F0-EFC4-40E4-916E-AE032D830C8D.jpeg 7BD56804-3D5F-4194-BCDD-1808D46960BC.jpeg 00F7F1E4-4C3D-45B3-8099-BCF89B84CC85.jpeg 02A16686-B1FF-4786-B5DF-C72CDEACAE1A.jpeg EF857154-D4E5-4C70-A167-7D3033715071.jpeg 563E0097-7E05-4128-B441-FA820A5DD77B.jpeg 8315430E-7798-4986-A60A-EAAF7A5DB059.jpeg
Just guessing here by the appearance - Mid '60's big blocks? 1" drop for "B" and 1/2" drop for "RB"?
I'll toss this out there for you - or whomever buys these - ...I could probably buy the cut base for a small portion of the package cost.
Mark
Could you lay a tape across the bottom of the base that does not have the cut? Snap a pic and post it? From edge to edge I’m looking for just over 18”. I know you said the top is 17.5”, wasn’t sure where you measured that, across the top our outer flange. Is the throat exactly 4”, or is it 4.25”?
The small center top where the pie plate goes is for a B engine.
The horn opening is 4 1/4”
74395DA8-468A-495D-B7FA-2161C09CEF28.jpeg F6E7F7D2-1A3E-481B-B4D4-930FB152F85B.jpeg 126D3589-3DAB-4740-B94E-4396A10E29F0.jpeg
The lid is correct for a 67 383 HP car. I'm not sure about the base, but I would assume the 1/2" drop.
Thx for posting. So many different ones out there and not interchangeable.
