71 Super Bee vs 71 Challenger 383 Mag Hood Emblems
JG71B
11:17 AM
NE OH
Can anybody tell me the difference between these two as far as dimensions or studs and how their configured? I'm looking at places like Classic Industries, Year One, supposed NOS on eBay and other repops that are available and even with part numbers it is confusing to know which is which especially how some are listed or if they are the same That is basically my question as I need some for the insert on my 71 Super Bee Hood. Appreciate any help
Challenger ones are not even close
Much much smaller in dimensions
I've never seen them side by side so I really can't remember how different they are to each other in terms of size. Thanks!
383 Magnum
70-71 Challenger about 5 3/4" Length 2 Pins
1971 Charger Hood about 10 1/2" Length 3 Pins
383 Magnum
Appreciate it. Emblems were missing on my hood insert and holes filled in when I found it
I have 72 400 Magnum emblems I could measure for you.
Agree B body emblems are MUCH larger than those for an E body.
So the 72-74 emblems go on the metal bulge.
71 goes on the fiberglass center insert.
Not sure about 71 with N96.
Pretty sure that doesn't matter, though.
That's exactly what I'm trying to figure out just not a hundred percent sure
In 1971
Superbee standard hood - Had the fiberglass/plastic hood insert
The 340 Magnum / 383 Magnum / 440 Sixpack Emblems where inserted into three holes on each side of the fiberglass/plastic hood insert - All those emblems will have the three pins in the same location - I gave the length of the 1971 Charger 383 Magnum emblem
Charger R/T standard hood with louvered metal hood insert
440 Magnum / 440 Sixpack Emblems three holes drilled in the metal bulge of the hood on each side
426 Hemi came standard with the N96 Ram Charger Hood
That emblem was on the outside of the metal bulge also - Three holes drilled in the bulge of the hood on each side
All N96 Ram Charger hood emblems - Three holes drilled in the metal bulge of the hood on each side
So in a nutshell - If your 1971 Superbee had the standard hood with fiberglass/plastic hood insert Those emblems where inside on the fiberglass insert
Everything else was on the outside metal bulge
I forgot about the 27 - 1971 SuperBees with the 440 Magnum
Those emblems same location inside the fiberglass/plastic insert unless it had the N96 option
In 1971
All emblems , three holes drilled in the bulge of the hood on each side
426 Hemi came standard with the Ram Charger Hood
That emblem was on the outside of the metal bulge - Three holes drilled in the bulge of the hood on each side
All N96 Ram Charger hood emblems - Three holes drilled in the bulge of the hood on each side
So in a nutshell - If your 1971 Superbee had the standard hood with fiberglass/plastic hood insert - Those emblems where inside on the fiberglass insert
Everything else I think I covered for 1971
Got all that, thank you, so dimensionally the Magnum emblems that go on the metal bulge are the same as the ones in the insert
Now the next question
You said your Superbee fiberglass insert has the three holes covered over or filled in ?
And you want to know where to drill or how to locate your 383 Magnum emblems within that insert
I'll have to look again when I go home at lunch I'm pretty sure there are two holes that are filled in but not certain
Also, is there some sort of seal that seals the inserted a hood so the elements don't get in while driving or sitting outside?
