Panel/Fender Molding
RedBeard
2:20 AM
North Dakota
Would like to know what tool/method has been used to remove the panel/fender molding off our cars. This especially pertains to the molding that starts from the doors to the J molding. Thanks.
Maybe this will help.
I carefully used trim removal tools and pried the peak mouldings up. Clips came with them.
I have several styles of these. Also metal and "plastic" styles. Any suggestions? Picture of what tool you liked best?
Actually I had some 1/4 inch polypropylene sheet material, cut a piece about 1/4 inch wide and 6 inches long. Thinned the ends down like a flat blade screwdriver. Slid them under the trim and gently pried them up, sometimes i would twist the tool. Also tried to locate the clips and pry there.
Think this would work?
I was just posting pictures of the clips that are used for each moulding. So you can either wiggle the moulding lose or a clip tool. Or un bolt from the back. The little book is handy. I got it with my car .
Yep, a great reference book. Found mine online.
