Rear Leaf Springs
Rick69
10:49 AM
Pelham, NH
On my Coronet there is about 3/4" difference in the ride height left to right in the rear. I thought I read somewhere that this could have been intentional. Some folks run their car with more lift on the right side. Any truth to this? I would like to set it up so both sides are 28" fender lip to the ground. Appreciate any advice!
If they're SuperStock springs, the Right side, should be the High side. Count the leafs. Maybe they're flipped ?
This.
Also check the torsion bar adjustments. Raising the right front puts more weight on the left rear and vice versa.
This.
I already tried adjusting torsion bars. No change. Local spring shop says they can rearch the springs to achieve 27" ride height on both sides
