SOLD MSD Pro-Billet Distributor / Chrysler Big Block
Clownbaby
4:40 PM
Sacramento
Feedback: +1 / =0 / -0
Up for sale is a SLIGHTLY used MSD Distributor W/ Taylor Spiro Pro 8mm spark plug wires
Price:$375
Overview:
Distributor, Pro-Billet Ready-to-Run, Magnetic Pickup, Vacuum Advance, Chrysler, 383-400, Big Block
MSD's Ready-to-Run Pro-Billet Distributors for Chrysler engines are the perfect upgrade from breaker points or weak electronic ignitions.
These distributors feature a maintenance-free magnetic pick-up that accurately triggers the built-in powerful ignition module. This module produces a high-output spark which improves combustion in the cylinder, resulting in quick starts, a smooth idle and great performance.
Just beneath the race rotor is a mechanical advance assembly so a timing curve can easily be tailored to match your application. The QPQcoated shaft is guided by a sealed ball bearing assembly for stability and endurance while a vacuum advance canister helps increase economy on those long cruises.
The Ready-to-Run Distributors are also a breeze to install. Simply drop it in the engine and connect three wires and you're ready-to-run to your favorite cruise! The front engine mount models are designed in a special small diameter housing to clear aftermarket heads and valve covers.
Features:
Simple and clean installation with only three wires to connect
CARB E.O. Approved
Supplied with a HEI style distributor cap and rotor (accepts Cap-A-Dapts)
Mechanical advance assembly can be locked out for crank trigger systems
Polished steel shaft is QPQ coated and guided by sealed ball bearings
Maintenance-free magnetic pickup and precision reluctor create stable trigger signals throughout the rpm range
Vacuum advance canister for improved economy (can be locked out)
Easy-to-adjust mechanical advance with supplied springs and stop bushings
Powerful built-in module produces a 7.5 amp single spark through high rpm
Now includes built-in Rev Limiter!
This distributor was on a Challenger project I bought. I decided to restore it back to original, so the distributor must go. It was only used to break in the newly rebuilt engine, and then just set aside.
The MSD "Ready to Run" is one of the best, most adjustable, distributors made. It is a great addition to any old school Mopar big block.
Summit Racing sells the Distributor for $546 and Spark Plug Wires for $75, Totally $621. As you may be aware; most speed / street parts are in short supply and can be back-ordered for months.
DSCN3566.JPG DSCN3567.JPG DSCN3568.JPG DSCN3569.JPG DSCN3570.JPG DSCN3571.JPG DSCN3573.JPG DSCN3574.JPG
