- 10:05 PM
- Feb 20, 2012
- New Hampster
Plastic with molded in gasket. Just curious how they hold up for leakage.
With an original pan they would likely seal better than it would with a Milodon 6 quart Hemi pan. I found out that the Milodon pan I have is actually 1/4" shorter in length than a stock pan. This poses no sealing problems with a regular steel windage tray gasket sandwich but those plastic combination windage tray/gaskets use thin sealing ribs. The outer rib sits too close to the edge of my Milodon pan.I have one and it’s excellent, just a dab of silicone in thenisual spots like where the timing chain case joins it etc…
View attachment 1206533 View attachment 1206534
Lay it on the 402 PanThis is a 402 pan.
24 3/8".
This is the Milodon pan:
Yeah, 24 1/16". maybe.
This is the windage tray, a generic one from Jegs.
The longer 402 pan covers more of the windage tray and probably seals better as a result.
