Stroker plus trick flow top end kit
19 69 GTX
1:18 PM
Has anyone built a stroker and used the trick flow top end kit with good results. I'm getting ready to put together a 512 low deck stroker with the Trick Flow top end package. It's a 10.4 compression street engine. Has anyone dynoed one with good results. Just curious with results I believe there is a article on one but just checking here for first hand experience. Are the lifters in kit good I have not ordered them yet
What are your plans for a hood? The Trick Flow intake is quite tall.
I used the TF240 heads and their .600 lift Hyd roller cam w/ Edelbrock RPM intake on a 400 block w/ 440 Source rotating assembly for 512 cu in.
Someone posted this on the facebook
Just did one with a .590 mopar cam and just about 11:1 comp. 634 HP. I used Johnson lifters.
