- 2:49 PM
- Feb 22, 2021
- Roswell, New Mexico
Hey all,
I've been doing some extensive reading/research
on the actual ZDDP requirements (for example:
a 1968 440 in stock form). Higher spring rates,
via drag racers's engines benefit from higher
levels, as well as breakins.
Too much ZDDP in your oil turns acidic
promoting spalling. Too little creates the
same problem. Those that run a specific
oil, then an additive, a question;
What would you assume the ppm of ZDDP
would be in your oil after doing so?
Those that manufacture the additives should
know that level when their product is added
to 5 quarts of oil. I can find no data to that
effect.
I realize this subject has been literally beat to
death here. Many can attest to the longevity
of their engines given their preferred methods
of application, but all cars are not driven equally.
effect.
