- 11:47 PM
- Feb 20, 2012
- New Hampster
Anyone got a spare that they no longer need?
Thanks!
Thanks!
PRI 2021: Engine Pro Debuts New LS MLS Gaskets, Mopar Windage Trays (enginelabs.com)Anyone got a spare that they no longer need?
Thanks!
Is there even a windage tray in a '76 engine..My motor is a 76 440 so let me know I can pop pan off and make sure of condition ..
I have seen some in police cars. They also had block heaters in them here in the North East..Is there even a windage tray in a '76 engine..
I just installed this one. I haven't tested it yet, but hoping to have it fired up early next week.
https://www.summitracing.com/parts/sum-g2339
Edit: sorry Richard, I didn't look to see who ask the question. I know you already seen my post.
Are you wanting an original or just a steel factory style tray?Anyone got a spare that they no longer need?
Thanks!
RC...I have put 2 into my BB engine builds and both came from Summit. I also used a Cometric Gasket to help with sealing. No runs, no drips, no leaks at all. I would be leery of the type you listed here. Just my take is all. The ones from Summit worked great and installed easily. I prefer to keep it simple when and if I ever build another engine...cr8crshr/BillThe one with the molded in gaskets intrigues me, but I've used that same style on a transmission pan and it still weeps.
They probably over torqued it as most do with oil pan bolts and valve cover bolts...I tried one of those. I couldn’t get the pan off because it was hitting the k frame so I had to send the car into town. They put the tray in and it leaked like crazy. You can see what happened in the picture. Not sure why the seal bulged out at the bolt holes. I contacted summit and they sent me a new one. Haven’t put it in yet.
But there are metal "grommets" around the bolt holes that are suppose to prevent overtightening and I'm pretty sure we confirmed that the bolts were only to be tightened to 15 lbs.They probably over torqued it as most do with oil pan bolts and valve cover bolts...
That's good most just put them on with air tools...But there are metal "grommets" around the bolt holes that are suppose to prevent overtightening and I'm pretty sure we confirmed that the bolts were only to be tightened to 15 lbs.
