FOR SALE 4.11 sure grip
3white74
12:45 PM
albany,ny
Feedback: 90 / 0 / 1
For sale one 489 case .....4.11 sure grip .....fresh pulled from a 69 roadrunner parts car...... everything looks good ..intact .....big yoke ......not sure what is up with all the individual small grind marks on it???......never seen this before?….... anyway .....,$.600....plus shipping.... thanks fbbo
IMG_20220109_143513203.jpg IMG_20220109_143533106.jpg IMG_20220109_143549624.jpg IMG_20220109_143554753.jpg IMG_20220109_143613083.jpg IMG_20220109_143625593.jpg IMG_20220109_143637613.jpg IMG_20220109_143654237.jpg
Seems to turn fine to me....no grinding or excessive play
410 sure grip still for sale
Yes but has 72 date on ring gear ....idk
That is an indication the pinion nut got loose and the pinion gear was pulled into the carrier... It could have happened with the previous gears or it could have happened with the current gears... Hence Kimmers request for pictures of the pinion gear... Either way it's a cone style SG.....
Not hiding anything old kimmer you want to call me out here you go.......stated in original ad just pulled from parts car ...don't know history and don't know what grind marks are from .....if you are rear end expert that's fine ....I am not !!!!
IMG_20220219_153451073_HDR.jpg IMG_20220219_153503775.jpg IMG_20220219_153518114.jpg
I don’t claim to be a rear ending expert. But I have set up about a hundred or so. I wanted to see 2 things. If the marks were from this set of gears or not. Yes they are. And if the gears were running off the end of the pinion. No they are not. Pinion nut definitely came loose. It may need a new crush sleeve. Kim
