Success (I believe)!
So I tried to adjust the front band a half turn. It didn't work and just seemed to cause some weird issues in the 1-2 shift. So I bit the bullet, put the band back the way it was and pulled off the pan and valve body.
Once the pan was down, I had to pull out the "E" clip that connects the shifter to the park lever rod. The park lever rod is not easy to insert into the transmission due to the Gear Vendors tail shaft, so it was easier to pull off the "E" clip and drop the valve body. In the picture below, my finger in generally pointing in the direction of this "E" clip, but it is not easy to see in the picture (the transmission needs to be in "1" or first gear to make this rod readily accessible).
Once the valve body was out, we had to come up with a way to pull the restrictor out (as seen in post 178 above). I found a larger wood screw and simply turned it into the opening of the restrictor. Since it was pressed in initially, I then simply grabbed the screw with a pair of pliers and hammered down on the pliers. Success! The picture below shows the screw and the restrictor plug.
Here is a close up of the restrictor plug. The original hole was square - you can see this got beat up as we worked to get it out.
We then reassembled the transmission and took it for a drive. The "engine flare" was gone and the transmission shifted nicely from first to second to third at both a light throttle and a medium throttle (full throttle not yet tested).
So the problem I had earlier is GONE!!!
Now, mind, you, it is still early. I am not ready to declare this project a success yet, but the test drive this evening was a success. Now to drive it some more over the next few weeks (depending on acceptable weather) and see how it performs.
So far so good! Thank you again for the FBBO brain trust helping me through this project!
Hawk
Hawk
