1968 Superbee wipers not working
milit73
1:24 PM
Vacaville, Ca
I am not sure if the switch is bad or the motor is bad. One day they just stopped working. I have tested the fuse which is good and the ballast has continuity. Not sure that it matters but the gas gauge stopped working around the same time.
Is there a way to test the motor to wiring straight off the battery to test?
Thanks in advance for any assistance.
try and extra ground to the motor. Had one on my D100 quite and that fixed it.
Do you have a wiring diagram?
^^^^ this
There is a procedure in the manual to test the motor. Go to my mopar.com and find a free service manual
Looking at the diagram there was no ground plate on the wiper motor. Added the ground and low speed is working but no high speed. I am fine with the result for now!!
