Any pics of b body with 18” or bigger wheels ?
Hi team,
Has anyone fitted 295/45-18 on the rear of a 70 Plymouth ? Any pics please
Hi team,
On a 68 Roadrunner
Thanks I know they fit as viewed from the photo, I’m more looking for a side view of front lower quarter/sill clearance please
28 1/2 tall. Shouldn't be too tall for a 70 runner, measure what you have now and compare. 5+" sidewall will fill the wheelwell without looking like rubber band tires.
I need to replace my tires. Currently are Falken 452's and I liked them a lot but no longer made. Anyone running General G-MAX RS tires? Also considering Firestone Firehawk 500's and Nitto 555's. Front 245/45-18 and rear are 275/40-18 on 72 B-body. Thanks
I’m running the Firestone fire hawks. I don’t have very many miles on them but no complaints so far.
I have a similiar question. I have a 69 Charger and I ordered 20x10 for the back and 18x9 in the front. I need to know what size tires can I go. Id like the back tire wide. Also I purchased new leafs but it will be 1 inch lower than factory
View attachment 1284544 View attachment 1284545
You are going to want to read THIS:
https://www.forbbodiesonly.com/mopa...g-rear-tire-clearance-in-a-70-charger.237976/
A wheel and tire that big along with a lower than stock ride height will result in some tire to wheel tub contact.
Also.....A large wheel will make stock brakes look absolutely silly. A ten inch drum in a 20 inch rim ?
I actually switched the rear drums to discs just for appearances.
I would do 20s all around
I don’t know about the foose wheels they look …. Dated
I had a difficult time trying to find rims that were 20 in that would fit. Spent countless hours trying to find some. They have 2 and 3 piece wheel but are very very pricey. I wanted black rims, but limited stock. Also the 2 and 3 piece takes 23 weeks to build.
I was interested in these rims but wouldn't work. I would have to put on spacers. I wasn't going going to put spacers on.
What’s wrong with the torq theuat wheels ? They look mean on all the b bodies
I went with Wilwood drilled and slotted all around. Thats why I wanted to go with a bigger and more open wheel to show the wilwoods.
